37 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall section visibility
Thu, Nov 16, 2006 at 10:26:16 AM | Wall section visibility
kesflower
3.5 Stars: 11 Votes
I created a couple of wall sections.  One of them shows up in nearly every view I want it to.  The other one, which has the same settings, is only showing up in the parent view (even though I've checked the box to tell it to show up in other views).  Is there a way that I can copy/paste this annotation?  It doesn't show up in views that have other section lines, so I know its not a visibility setting.... I just can't figure out where it went or how to get it back.
 Also, I've got one view that none of my sections are showing up in, even though it has the proper visibility and even though the sections go through that level.  Its at the same scale as other drawings, so I know it's not a "don't show up in a view coarser than" issue.  If someone hit "hide annotation in view" to get it out of the way for a while, is there any way to get it back?  I think that may be what happened.  But they don't highlight when I scroll over where they should be like other hidden annotations do.
Thanks for any help
Ruth Rau
Main Street Architecture, P.C.
Thu, Nov 16, 2006 at 10:31:38 AM | Wall section visibility
kesflower
3.5 Stars: 11 Votes
ok, I solved the 2nd problem.  It was a structural vs architectural view.  When I switched the view to architectural, most of my sections showed up.
The first problem, however, as to why that wall section annotation is only showing up in one view, is still a mystery to me.
thanks for any help.
Ruth Rau
Thu, Nov 16, 2006 at 12:04:47 PM | Wall section visibility
kesflower
3.5 Stars: 11 Votes
And I solved the first problem!! I simply told it to not have a parent view and voila! it appeared in all of my views.
Ruth Rau
Thu, Nov 16, 2006 at 12:27:58 PM | Wall section visibility
framerman
4 Stars: 13 Votes
hey, no problem. glad I could help. LOL
Earth and Wall cut patterns not showing in wall section...
Thu, Jan 5, 2012 at 3:08:36 PM
Reference plane visibility in section
Mon, Aug 27, 2018 at 7:11:50 AM
Wall not showing in section
Tue, Apr 23, 2013 at 4:19:40 PM
Having visibility issues in view section
Wed, Mar 4, 2020 at 4:06:02 PM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Page generation time: 3.4889
