62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Isolated foundations (pile caps) on sloping surface
Wed, Nov 15, 2006 at 5:50:09 AM | Isolated foundations (pile caps) on sloping surface
SeanCouzyn
Has anyone had experience in placing isolated foundations (pile caps) on a non-flat uniform level?
We have a multi-storey project built on a slope. We have successfully modelled the sloping surface bed and attached our column bases to an offset distance to achieve the column bottoms at a uniform distance down from the surface bed slab. Now that we are attaching pile caps to these columns, we cannot make the pile caps attach to the bottom of the columns - they display correctly in plan view, but the levels are incorrect. The pile caps are inserted at a uniform level, not following the actual levels which vary by 7m.
Any suggestions please.
Wed, Nov 15, 2006 at 1:21:47 PM | Isolated foundations (pile caps) on sloping surface
TomDorner
4.5 Stars: 25 Votes
I'm not a Stucture user, but sound like a custom or modified family is needed that allows for a slope.  You could always do a in-place family to get you by if you can't create the new family.
HTH
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, Nov 15, 2006 at 11:17:21 PM | Isolated foundations (pile caps) on sloping surface
SeanCouzyn
Thanks for suggestion. However our problem is more about getting a conventional flat bottomed foundation/ pile cap to attach to varying offset column bases. There are in excess of 850 foundation positions so I would really prefer not to have to create in-place families for each one!
Joining isolated foundations to concrete beams - 2009
Thu, May 7, 2009 at 1:43:53 AM
Isolated foundations attaching to columns
Thu, Oct 16, 2008 at 5:15:42 PM
Creating a Pile Schedule
Mon, May 23, 2011 at 10:37:28 AM
Pile cap issue
Thu, Jun 3, 2010 at 7:22:28 AM
Ground beams not joing to pile caps (but usually work fine)
Thu, Feb 18, 2010 at 6:27:46 AM
Page generation time: 0.2822
