86 Users Online (85 Members):
Forums >> Revit Building >> Technical Support >> Group troubles
1 Posts No Rating |
Is anyone having or have had problems with groups changing themselves once copied or mirrored? I've created a group of a custom storefront window, so, of course, once changes are made to the window, all references will update. My trouble is when I get the window to the point/mullion-frame layout I want, then I go to copy or mirror the windows throughout the building, the window frames and mullion assignments change and additional curtainwall grids are added on its own. Anyone have this problem or have any suggestions on how to address/fix the issue. Thanks RJ
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
I suspect the ends will change because of different connections to the walls on either side (?) not sure if you will have to go and edit each end connection, maybe disallow jointing on your walls?? have you created a curtain system? if so, you should have the set numbers of mullions you specified in your system, strange that it's adding more... in truth, it might be easier to draw each curtain wall system, I never grouped curtain walls before...
INSERTED GROUP - COPIED GROUP - DIFFERENT RESULT [ 1 2 ] |
Wed, Nov 23, 2016 at 3:27:29 PM
15
edit group panel missing |
Tue, Jan 17, 2012 at 2:54:43 AM
12
can't make change to group with more than one instance [ 1 2 ] |
Sun, May 21, 2017 at 1:30:17 AM
16
Group phases |
Thu, Jul 10, 2008 at 5:21:58 PM
Switching off group Revit 9.1 |
Thu, Jun 21, 2007 at 6:56:19 AM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
