37 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> higher-quality renderings
is there a way to improve the rendering quality from the "presantion" setting? and how long would a higher one take?
----------------------------------- My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087 |
Probably the quickest and easiest way to improve rendering quality is to go to Settings -->Radiosity settings-->Quality (change higher ... I use Better)-->Raytrace Settings-->Quality (change higher ... I use Best). Also change your image size to between 300 & 600. As to rendering time, in addition to the changes you make to settings and image size, it also depends on how large your rendering is and how much stuff you have in it as to how long it will take. If it seems like it's taking too long, I usually stop the rendering process and change the settings lower, although I usually don't change the image size below 300. You just kind of have to play around with it and see what works for you and your individual rendering. I don't know if this will help you or not ......
thanks, i think i might know one resaon that it takes a while to render is that my pc is slow
You're welcome. Yes, the speed of your PC will slow down the rendering process, unfortunately : -)
i hope to get a faster laptop soon....
Rendering Quality |
Tue, Feb 26, 2013 at 10:20:31 AM
11
Renderings |
Fri, Oct 23, 2015 at 9:21:12 AM
import revit renderings into autocad |
Mon, Jan 17, 2011 at 2:18:17 PM
Render Quality |
Thu, Apr 28, 2005 at 3:27:47 PM
Rendered products are not a very high quality |
Fri, Mar 6, 2015 at 1:52:00 PM
Members: | 2066439 | Objects: | 23085 | Forum Posts: | 152257 | Job Listings: | 3 |
