61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Irregular Shaped Callout
Sat, Nov 11, 2006 at 3:16:25 PM | Irregular Shaped Callout
scooter101
Is it possible to create an irregular shaped callout rather than the rectangular callout?
Mon, Nov 13, 2006 at 7:39:56 AM | Irregular Shaped Callout
laurabh
No.  You're stuck with the rectangle.
Mon, Nov 13, 2006 at 4:47:40 PM | Irregular Shaped Callout
arkitektmsh
3 Stars: 1 Votes
On that note, is there a way to either turn the callout line off on specific callouts or create a new callout view type that has no callout line. We have enlarged unit floor plans and need to reference them without having a box around every single unit.
Thu, Oct 4, 2007 at 11:13:00 AM | Irregular Shaped Callout
kirchmer
I have a similar problem. I am creating enlarged plans and interior elevations to go with them and i really need a way to turn off the lines and retain the tag - our rooms aren't rectangles and the reference plan needs to be accurate. is it possible to do this?
Thu, Oct 4, 2007 at 12:14:26 PM | Irregular Shaped Callout
Simple - hide the call-out in the view ... The view doesn't go away.  And if you want to have a funky shaped callout line with your own call-out bubble, you could do that using your own linework .... just like you had to in you know what.
Thu, Oct 4, 2007 at 1:35:32 PM | Irregular Shaped Callout
kirchmer
i had hoped that there was a way to keep the call out bubble. i have tried changing the visibility of that particular object under the object styles menu but it applies the chagnes to alll views and i simply wanted to change them in the finish plan
Thu, Oct 4, 2007 at 1:42:22 PM | Irregular Shaped Callout
laurabh
If you just want to show it in one plan, you can use visibility/graphics overrides (View -> Visibility/Graphics) to override the settings in Object Styles for a single view.
Thu, Oct 4, 2007 at 1:51:12 PM | Irregular Shaped Callout
kirchmer
when i edit the object styles it will apply the changes to all of the views in the project (i would like the call-out boundries on my wall sections to stay in-tact). is there another way to access the call-out boundry setting that is view or element specific?
Thu, Sep 9, 2010 at 3:19:13 PM
customerized curtain panel doesn't work with the irreglar shaped panel?
Sat, Jul 10, 2010 at 1:48:43 PM
Irregular Ceiling
Mon, Aug 4, 2008 at 1:45:53 AM
Irregular (on plan) shaped walls
Thu, Nov 23, 2006 at 3:28:48 AM
Curving a Truss around an irregular mass
Sun, Mar 1, 2009 at 8:19:45 AM
Page generation time: 2.0304
