Forums >> Revit Building >> Technical Support >> Linking Revit Files instead of groups
My firm does alot of prototype hotels with similar unit layouts. Right now we use groups to group our bathroom types and copy them around the building. We are trying to come up with a more efficent way because there seems to be alot of errors associated with groups when adjusting floor to floor heights, most of the errors have to do with ceilings inside of the groups. Our idea is to use links to place the bathrooms throughout a project. We create the unit type in a seperate file and then link it into Revit and copy the link around to the right locations. Has anyone ever attempted to do this before on a project? I can tell there are going to be alot of visibilty problems because levels for each link will show up in every view, but I'm wondering if the advantages would out weight the disadvantages. Please let me know what you all think. Thanks, Adam
Never tried it. sounds viable tho, as long as your plumbing fixtures aren't wall based. You will have some problems with wall joins in external files.
11 Posts No Rating |
Hi Adam, You bring up a good point about visibilities in the view. We have not gone beyound discussion on the matter here and have speculated if wall cleanups would also be an issue............ Our office does a lot of huge senior living projects, so far we are still using the group approach and hoping to find or develop non-hosted casework, etc. Carla
Hey Carla, Nice to hear from you again. Yah we are having some serious problems with ceilings and ceiling hosted families in groups. It seems on every project there is always a need to change the floor to floor heights, and there is never an easy way to do it without tons of errors popping up, mostly due to groups and ceilings. For some of our hotels, our clients actually use pre-built modular bathrooms complete with all interior finishes that are shipped to the site and then slipped into placed. We are trying to come up with a way in Revit to keep groups like that outside of the file and then put them right into place without all kinds of errors. Adam
Hello again, I have added gyp ceilings to groups along with raised walls for the side soffits, but have not gotten to the point in my project to try and add actual components to ceilings and groups. Hope Revit can improve on these kind of things and fast. You made me think of one thing I had to be very careful of in adding groups as far as the wall joins..... I have curtain walls as groups and found that I had to 'disallow join' on some of my end walls and curtain wall ends. Otherwise, they groups wanted to ungroup. Same thing with walls to walls. Might work to your advantage in treating them as seperate files if there isn't a clean up between files. I need to run a test, give it a try and see if that is the case. As far as floor to floor heights and groups. I found that I could not join walls to the ceiling above when using groups or they errored. Had to tell them to be a specific distance from the floor above. The perk with blocks in CAD was being able to put a block in a block. You could have a bathroom, kitchen, etc. that repeated in rooms that didn't necessarily have the same floor plans all combined. If I figure anything out any time, I'll share...... and/or watch to see if you or someone else finds a solution. Good Luck!
Carla and Adam I was just wondering if using links was successful for you all. We do a lot of hotel work and I am having problems with guestroom groups just randomly ungrouping. It's very frustrating I think we may need to use links.
Probably rehashing but here it goes: 1. Groups should not join to objects outside of the group if at all possible. So if you have walls in a hotel room group that hit demising walls that are not in the group, they should not be joining to that wall. 2. groups don't randomly ungroup. someone is not reading their errors when they are making changes to groups.
If you get an error with editing a group, wouldn't it ask you if you want to ungroup the group?
Yea and someone is ignoring it.
Hi, I would like to introduce Design Presentation is a premier BIM support service provider to the AEC firms worldwide. AEC firms around the globe are transitioning from 2D CAD Platforms like ACAD and Micro station to 3D intelligent modeling in BIM. Design Presentation understands and caters to the needs of the industry has invested in the leading BIM solution softwares like: -
- Autodesk® Revit ® Building
- Autodesk® Revit ® Structures
- Graphisoft Archicad ®
- Bentley Triforma
- Google Sketchup
Founded in 2002, the company has offices in New Jersey, London, Australia and New Delhi. Design Presentation employs a staff of more than 200 Professional Architects, Engineers, and Interior Designers on board trained on latest softwares. We are catering to 600 clients worldwide and have partnered with top AEC firms across the globe to complete over 2500 projects in various countries we cater to the market segments like retail, residential, healthcare, hospitality, institutional, corporate, etc. Following are the range of our BIM support services: -
- Creating Building Information Model
- BIM related 3D Visualization and Animation
- Embedding/linking and extracting of various Information from the model
- Conflict Detection
- Design Coordination
- Content Creation
BIM support services at Design Presentation provides you with an efficient way to transition from 2D platforms to intelligent modeling in order to reduce project cost, increase profitability and save time. We would like to fix up a Online Presentation with your organisation at a convenient date and time suitable to you. In this presentation we would like to showcase our services in detail and look for probable areas of mutual collaboration. Thanks Regards Max(max@design-presentation.com) 877-206-6908 or Cell : +919810892358
can that guys account get deleted?
Linking Revit Files for Sheet Coordination |
Fri, Jul 10, 2009 at 11:09:10 AM
Linking Revit Architecture files |
Sun, May 12, 2013 at 11:05:16 AM
Linking Arch file into Struct and using Arch groups? |
Tue, Jan 18, 2011 at 7:44:20 AM
Linking large files |
Wed, Aug 31, 2005 at 2:32:02 PM
Problems linking DWG CAD files into Revit |
Wed, May 14, 2014 at 10:33:53 AM
Members: | 2100306 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
