87 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Inserting stone into brick veneer
Fri, Nov 10, 2006 at 8:24:23 AM | Inserting stone into brick veneer
MrBob
3 Stars: 2 Votes
I am trying to insert a portion of stone veneer into a brick veneer wall.  For the elevation, just created a window opening with a stone insert.  It works for the elevation but when I cut a wall section it doesn't look right.  Was wondering if any body had sugguestion on how to show this correctly.
I have attached a pdf of the elevation and section.  Thanks
Mon, Nov 13, 2006 at 9:58:32 PM | Inserting stone into brick veneer
eldados
eldados Avatar
4.5 Stars: 8 Votes
Instead of a window opening, try edit wall profile and cut out your square where needed, than insert the stone wall
HTH
Integrator
KarelCAD
Stone Wall
Tue, Aug 20, 2013 at 3:55:34 PM
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:59 AM
Stone Veneer and Framing Plan
Wed, Nov 14, 2007 at 12:12:23 PM
brick veneer window insertion question
Tue, Nov 23, 2004 at 4:28:50 PM
Brick veneer stepping at alternate elevations
Wed, Aug 14, 2013 at 8:28:37 PM
Page generation time: 1.5125
