88 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> pattern files
I am learning Revit through tutorials My project is to design my highschool in revit. So far, I have put in the foundation walls, the floor, the walls, the ceilings, the ramps and stairs I want to apply textures (brick, tiles) to what I have built so far. I went through the galleries and I don't understand how everyone makes the buildings so realistic I don't know how to make .pat files. I read that you can make them with photoshop but my photoshop wont save in that format Is there any other program you use to make the buildings look like that?
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
First, your Revit comes with lots of pattern files, I'm sure you can find Bricks pattern there. you will need to go to your wall properties-->edit/new-->edit structure and change your material. you can import ACAD .pat files into revit as well. if you want to create a new pattern all together, there is a program that you will need to purchase, it's somewhere on the forums... ![Smile](/images/smiles/smile.gif)
Pattern (.PAT) Files |
Mon, May 3, 2021 at 4:51:04 PM
Pattern files |
Sat, Sep 16, 2006 at 5:11:34 PM
Use Pat Files |
Tue, Sep 1, 2009 at 4:18:40 AM
11
Pat files corrupt |
Thu, Jan 22, 2009 at 3:20:12 PM
Patern Files |
Wed, Nov 16, 2005 at 2:53:56 AM
Members: | 2016987 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
