87 Users Online (86 Members):
Forums >> Revit Building >> Technical Support >> Plots which fail to plot to scale
![3 Stars: 1 Votes](/images/stars_3.gif) |
One of my students has a complete set of floor plans finished and dimensioned at 3/8" = 1'-0". The view properties verify that the view is at this scale. When the view is placed on an ANSI-D sheet, using the REVIT Residential template and plotted the views fail to plot at the stated scale. On this student's station, I personally created a new project using the same residential template, and plotted my results and all was to scale. Any advice would be appreciated.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
hmmm, strange, the only thing I can think of (and I'm sure you check it) is the plot setting on his machine, current view, or visible portion of the view...
Yes, I did check the plot settings. Also sent his file to a different plotter in our room and came up with the same results.
Are you shure your plotting at zoom 100%
holly, thank you, i checked the zoom plot and it was off. Once set to 100% all was well.
Printing: Window area for quick plots |
Tue, Jun 5, 2018 at 10:06:23 AM
13
Dropped lines on plots |
Tue, Mar 30, 2004 at 2:45:58 PM
Printing problem |
Tue, Dec 13, 2005 at 4:20:07 PM
Annotation Scales |
Sat, May 21, 2011 at 8:26:26 PM
Sheet title block plots incorrectly |
Wed, Nov 3, 2010 at 10:44:30 AM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
