62 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> ELEVATION TAG CAN'T PRINT
6 Posts No Rating |
Hi, guys I have two question regarding elevation tag. 1. few days ago, I place some new elevation tag in my plan and reference all the elevation arrowhead, then print. only the primary arrowhead can be printed, that doesn't happen before, and i found out the rest of arrowhead become dark grey color, it's hard to tell the difference if you don't look closely. did i do something wrong? how can i fix it? 2. I have some exposed structural columns in my corridor, and the elevation only show column as a thick line not in real thickness. i try to cut a section to see what happpened, it's the same. only lines. How can i make the column show its true thickness? thank you very much
FOR THE COLUMS TURN THE DETAIL LEVEL TO MEDIUM OR HIGH (BOTTOM LEFT CORNER OF THE VIEW WINDOW NEXT TO THE SCALE.
6 Posts No Rating |
THANKS, MAN HOW ABOUT THE TAG CAN'T PRINT? ANYONE?
elevation arrowhead don't show up at print |
Tue, Nov 14, 2006 at 1:26:57 PM
Elevation Tag Doesn't Work in Rotated Viewport! |
Wed, Aug 10, 2016 at 6:16:18 PM
Interior Elevation Tag |
Wed, Dec 19, 2012 at 2:25:25 PM
elevation tag line weight |
Wed, Dec 17, 2008 at 1:55:39 PM
Interior elevation tag |
Wed, Apr 8, 2009 at 11:30:17 AM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
