56 Users Online (55 Members):
Forums >> Revit Structure >> Technical Support >> Errors and warnings crashing out of Revit.
1 Posts No Rating |
I started a new revit project, the first for our company, everything was good until we made changes in the building shape. I moved my walls and there are multiple errors I know in the file do to the slab needing modified, etc. I try to put new walls in and I get a serious error and tells me to do a save as. If I try anything after that it crashes. Has anyone had experience with this problem? Does Revit have issues if you start bldg up errors. I haven't cleaned out the errors yet because I am trying to send drawings out and I planned on doing that after drawings are sent.
Just a little tip: sometimes walls will attach themselves to floors up and down and by moving a wall you can affect slabs and so on, the best thing is to copy the wall to your new position, delete the old one and clean up. after that you can edit your floor sketch HTH
Rotate Project North results in 100's of errors. |
Fri, Mar 11, 2011 at 2:33:17 PM
Run Time Errors |
Fri, Aug 22, 2008 at 3:16:17 AM
Errors linking CAD into Revit |
Wed, Jan 30, 2013 at 3:14:10 PM
Syncronization Issue |
Tue, May 28, 2013 at 1:06:48 PM
Clear out warnings to increase file speed. |
Tue, Nov 27, 2007 at 4:14:46 PM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
