58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> floor finish limits
Thu, Nov 9, 2006 at 8:49:12 AM | floor finish limits
dgwarchitect
when developing a floor system for a house how does one show different floor finishes from room to room.  the same structure will be under the living and bath, but floor finishes for each room will be different.
Thu, Nov 9, 2006 at 4:57:43 PM | floor finish limits
framerman
4 Stars: 13 Votes
use the split face command then use the paint tool
Thu, Nov 9, 2006 at 6:12:01 PM | floor finish limits
Cogen
You might also consider using a "thin floor" to represent the floor finish and separate from the structural floor.  You can split the face of the thin floor independently from the structural floor, and also adjust thicknesses if needed.
Fri, Nov 10, 2006 at 9:12:33 PM | floor finish limits
Dgodfrey
4 Stars: 4 Votes
Use color fill command defined by room. This is designed to accomplish exactly what you're looking for.
Tue, Dec 19, 2006 at 6:47:44 AM | floor finish limits
latemore
latemore Avatar
3 Stars: 2 Votes
i think gogen's option is best.  the others are good too, but we have learnt to adopt mr spot's suggestions on this site, to use revit to literally build the model.  this includes 'thin' floors.  that way any section or detail looks correct.  of course, what do you do at sketch design stage?  then it is ok we find for example to use composite floors and rooves, changing them later when we insert structure.  i have even started creating multiple walls sometimes, and cutting openings in those that do not host a window or door - again a bit like the real building.
revit is the best!
Tue, Dec 19, 2006 at 11:59:08 AM | floor finish limits
derxaj
3.5 Stars: 3 Votes
We also use the "thin floor" method. It works great for us because our floor to floor heights go from structure to structure not finish to finish. We keep the finishes seperate, usually making the finishes 1/2" thick or whatever the actual floor finish is.   They can be easily scheduled independantly of the structural floor, and you can also add a slab edge sweep to the floor to create base trim, which can also be scheduled where as wall sweeps can't be scheduled for some strange reason.  Also if your clients use DWF's for viewing their projects, ours enjoy being able to select a floor finish in a 3D DWF and know exactly the square footage of that floor.  For us there are more benifits then using the "thin floor" or as I like to call it the "finish floor" method rather than the split face tool, which seems to have problems sometimes if you are making major changes to the building.
 Adam
Finish Flooring as part of Structural Floor assembly
Fri, Dec 26, 2008 at 8:42:15 PM
Finish Floor
Tue, Jul 21, 2009 at 5:05:39 PM
Adjusting model from finish floor to subfloor
Wed, Feb 26, 2014 at 2:12:06 PM
Subfloor Vs Finish Floor Elevation
Tue, Jul 15, 2014 at 7:58:05 AM
floor finish showing though
Thu, Oct 6, 2011 at 12:29:12 PM
Page generation time: 0.9359
