109 Users Online (108 Members):
Forums >> Revit Building >> Technical Support >> Room tags to show in all plans
2 Posts No Rating |
I have room tags that show up in 1/16" scale plans but not in 1/8" scale. I looked at the visibilty options there does not seem to be any option there. Please help
Thanks
Chirag
5 Posts No Rating |
hi,
first go to ur plan where u wanna view the tags, then go to the modelling in the options bar and there u have a option saying TAG ALL NOT TAGGED, select that it will give u the option what tags u wanna apply.. eg. door or window select that. all the doors/windows in the plan will be visible. but firstly check that ur tags families are loaded
Post edited on 2004-11-03 13:23:08
Room tags are view specific, meaning they only show up in the view you place them in.
If you have two plan views and want tags in both you'll need to place them in both. If you select all of them from one plan view, then EDIT>COPY to CLIPBOARD you can paste them into the other view. With the other view open choose EDIT>PASTE ALIGNED>CURRENT VIEW
Also, be aware that room tags are also phase specific so you have similar issues if you are moving from existing to new phases.
Post edited on 2004-11-03 14:02:51
Post edited on 2004-11-03 14:03:40
3 Posts No Rating |
If you have already tagged the room in a different view you can go to "Room Tag" under the drafting toolbar & it will place the correct room # and name back in that room.
Room Tags on Ceiling Plans |
Fri, Mar 4, 2005 at 9:36:28 AM
Room Tags on Demo Plans |
Mon, May 9, 2022 at 3:23:12 PM
Want to see Room Tags but not Rooms |
Wed, Oct 5, 2016 at 11:37:51 PM
Room Phasing |
Thu, Dec 4, 2008 at 5:22:09 PM
Portion of Room tags show up in one plan but all show up in another... |
Wed, Mar 19, 2008 at 11:41:50 AM
Members: | 2030682 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
