Forums >> Revit Building >> Technical Support >> wall wraps
4 Posts No Rating |
Modelling a wall with a tile wainscott. the walls have internal and external joins. There are are wing walls- joined 1 end, but the other end is free and has tiles on both faces. in plan all the layers wrap and join correctly. The perimeter walls only have tiles on the internal faces. In 3D or elvation there are 2 problems. On the free ends, the wrapping of both substrate and finsih does not occurr, the substrateis is visible. At the 3 way joins ot T joins (2 sided tiles joining single sided joints), the tiles on the internal corners join correctly but the substrate and core stop the thickness of the tiles short of the wall they joining.Any tips on correcting this? Thanks
admin
It would be helpful if you added an image or two to describe the problem, I got confused reading the description
Hiroshi Jacobs
The Catholic University of America |
4 Posts No Rating |
2 screen shots follow. I shows the plan view- cut through the tiles and the other the 3d view. The plan view is correct with layers wrapping. The 3d view has aumber of issues; at the top you can see that the gyp bd layer does not join and ther appears to be a gap at the tiles, they do not wrap around the end of the wall, the top or bottom line is not carried around, the tiles do not project as they do on the wall faces and the model pattern does not wrap thanks Jonathan Edited on: Sun, Nov 5, 2006 at 3:50:32 PMEdited on: Sun, Nov 5, 2006 at 3:56:24 PMEdited on: Sun, Nov 5, 2006 at 3:56:59 PM
Edited on: Sun, Nov 5, 2006 at 3:59:09 PM
Wall Wraps |
Fri, Oct 17, 2008 at 1:17:25 PM
13
Wall wraps at inserts |
Tue, Jun 28, 2016 at 3:50:38 PM
Door deletes when I edit wall type. |
Mon, May 1, 2006 at 2:27:03 PM
wall wraps |
Tue, Jan 31, 2006 at 4:47:15 AM
Wall wraps |
Tue, Sep 25, 2007 at 11:29:19 AM
Members: | 2115045 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
