Forums >> Revit Building >> Technical Support >> Importing CAD drawing into Revit
Wed, Nov 1, 2006 at 10:26:43 PM | Importing CAD drawing into Revit
shiuh
Hi all,
 i imported a dwg file into revit.   in order to modify the dwg in revit...i have fully explode it.   this however have caused my computer to run EXTREMELY SLOW.   tried purging the file also but no luck.
the computer seems running very slow doing just 2D linework.   i would suspect the different line types in cad file that causes this slowness.  is there a way to speed up the program?  this is getting qquite frustating
Thu, Nov 2, 2006 at 5:29:30 AM | Importing CAD drawing into Revit
jfurlong
this may not be exactly what you want. with one dwg attached your computer shouldn't be running slow but you caould try linking the dwg instaed then if you need to modify the dwg, do it in autocaed and relaod the link.
aslo if try cleaning up the dwg. deleting the parts of the drawing that you don't need, getting rid of the hatching also helps
Thu, Nov 2, 2006 at 5:32:23 AM | Importing CAD drawing into Revit
shiuh
it is a furniture plan where are many funiture blocks in the cad file.  could this be the reason why?
Thu, Nov 2, 2006 at 5:46:25 AM | Importing CAD drawing into Revit
jfurlong
possible, try exploding the blocks in cad before you import or link the file
Sat, Nov 4, 2006 at 4:36:37 PM | Importing CAD drawing into Revit
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Hello,
The best practice that we have found to do this is to bring the CAD file into a seperate Revit file (Drafting View).
Revitize the CAD drawing and do a purge. This will not get rid of everything that is brought in from the .dwg file but when you later bring this into your current Revit file it prevent unnecessary Revit items from coming in.
After you have your CAD file Revitized, go into your current Revit file and go into the File menu and select "Insert From File" then select the "Views" option and select the Revit file which you just created from the CAD drawing.
It is generally not good practice to bring these CAD drawings into your current projects since it is rather difficult to get rid of CAD elements and in some cases not possible.
There are other things that you can also do to keep your computer from being bogged down, such as:
Keep all hidden windows closed as you are working. This is a good idea to do before a save as if ithey are not closed, Revit will regen all these windows upon opening.
Purge your file a few times a day. You can always reload what you might need later, also helps with the file size.
Last, Audit your drawing upon opening about once a week, maybe a little more. The slow opening times are worth more than the time wasted waiting for a corrupt file to be recovered.
Hope this was informational.
Importing a cad file
Fri, Apr 27, 2012 at 3:33:21 PM
CAD files importing with huge blank space [ 1 2 ]
Fri, Sep 3, 2010 at 11:43:39 PM
16
Importing CAD 3D
Sat, Mar 7, 2009 at 7:26:45 AM
Cad not importing correctly into revit
Mon, May 2, 2011 at 11:36:00 AM
Xclip an inported CAD image in Revit
Wed, Aug 4, 2010 at 2:26:12 PM
Page generation time: 1.7360
