76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Area Plans
Wed, Nov 1, 2006 at 9:42:18 AM | Area Plans
scaledup
After you create a new Area Scheme under settings, how do you change the names of the Area Types?  For example - The Rentable Area Scheme has the Area Types - building common area, office area, exterior area, floor area, major vertical penetration, and store area.  I want to make one for a City Hall, so I would like my own Area Type categories.
Wed, Nov 1, 2006 at 10:03:13 AM | Area Plans
TomDorner
4.5 Stars: 25 Votes
The Area Types built into Revit are BOMA types.  You can add your own Area Type definition though.  This is best done by using a "shared" parameter which will allow for proper scheduling and tagging.  If you have not doen so, establish a "shared parameters" file (see Revit help menu).  Once shared parameters file is established, create a shared parameter in the shared parameters file (hint: carefully organize your shared parameters file).  Assign newly created shared parameter to "Areas".  Fill in the parameter in yur area and then yu can colo fill and schedule by yur new parameter.
HTH
Tom
www.reviteer.com   http://twitter.com/Reviteer
new Area Scheme question
Tue, Jun 20, 2017 at 4:11:50 PM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:34 PM
Area Plans for design options
Fri, Jul 21, 2017 at 1:37:37 PM
area plans again?
Wed, Sep 14, 2011 at 9:07:34 AM
Stairs and Area Plans...
Thu, Nov 29, 2007 at 4:40:41 PM
Page generation time: 0.3688
