136 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall reveal - Vertical
Wed, Nov 1, 2006 at 9:35:25 AM | Wall reveal - Vertical
quiller
quiller Avatar
2.5 Stars: 3 Votes
I’m creating an as build model for a barn we’re working on. I want to re-create the wall as built. It basically 2 x 4 construction with 4” clap on the outside, a layer of barn boards on top of the stud layer. There is nothing on the inside, so you’re looking at the exposed studs, which is something we want to see when the project is completed. I want to build the wall as is, so I can see the studs on the inside. I played around with the reveal tool, but I can only get it to reveal along the length of the wall and not vertically. My reveals just cut a hunk out of the wall in the horizontal plane and I need then to go in the other direction and be 20” O.C etc. I sure I’m missing something very simple. Thanks in advance.
Thu, Nov 2, 2006 at 9:16:10 AM | Wall reveal - Vertical
MrBob
3 Stars: 2 Votes
Next to the type selector are the vertical/ horizontal buttons.  Pick on the vertical button to make the reveals go in the vertical direction.
Thu, Nov 2, 2006 at 10:37:58 AM | Wall reveal - Vertical
quiller
quiller Avatar
2.5 Stars: 3 Votes
MrBobI need to do this in the wall definition (properties of the wall), not in the model. I was aware of the vertical/horizontal buttons in the reveal tool.Thanks for trying........
Thu, Nov 2, 2006 at 1:17:49 PM | Wall reveal - Vertical
framerman
4 Stars: 13 Votes
well, I don'y know if this will help you, but once I tried making a wall using the structural floor framing system. You make your "floor" depth the height of your wall studs. I went into the family editor and created a new wall the height of the "studs" and imported it into my project. At least that gave me the studs without a whole bunch of modeling.
 Actually being able to model studs, plates, headers, sills, etc in walls would be really nice of Revit to do. Is it built into Revit structure?
Edited on: Thu, Nov 2, 2006 at 1:33:19 PM
Wed, Sep 2, 2009 at 10:39:23 AM | Wall reveal - Vertical
apanico
Quiller - - have you ever found a way to place a vertical reveal in the assembly editor?
I was told on AUGI that it is not possible.  Just wondering if you had any insight.
Wed, Sep 2, 2009 at 10:46:17 AM | Wall reveal - Vertical
Sorry but as far as I know, vertical reveals can only be placed after the wall is placed.  But you could have a wall already setup with multiple verticals placed and you copy that wall around.  Almoast as good....
Wed, Sep 2, 2009 at 10:54:59 AM | Wall reveal - Vertical
apanico
Gotcha  - thanks.
vertical wall reveal troubles
Wed, May 6, 2009 at 3:22:52 PM
How do i make a foam wall with repeating vertical reveal
Sat, Nov 18, 2017 at 10:50:48 PM
how to add a self made reveal to a wall while edit wall types?
Sat, Feb 12, 2011 at 10:53:31 PM
Is it possible to put reveal on a wall that has been edited with a profile?
Wed, Mar 2, 2016 at 6:54:33 AM
Vertical reveals to angle wall end
Mon, May 11, 2009 at 11:36:00 AM
Page generation time: 1.7205
