56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> about scheduling
Sun, Oct 31, 2004 at 11:33:51 PM | about scheduling
iPang
Hiii...I'm new to Revitcity forum. I have a case confusing me recently. When I create a multi-category schedule, it doesn't display all building elements created. No floor, wall, roof, etc. I need to make it for building cost estimation. Someone suggests me to export to ODBC but I'm still don't understand with this feature since I'm new to Revit. Anyone can teach me? Thx. Smile
Mon, Nov 1, 2004 at 12:56:09 AM | RE: about scheduling
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What program do you want to export to?
Mon, Nov 1, 2004 at 1:41:37 AM | RE: about scheduling
iPang
I prefer working with Excel to Access.
Mon, Nov 1, 2004 at 4:32:11 PM | RE: about scheduling
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Okay, First open excel and create a blank workbook and save it in a location. In Revit: Go to File-->Export-->ODBC Database... Click on Machine Data Source Tab and double click excel files. Then find the file you just created and click okay. Now all information from the project will be exported out to this file. Open the file and each different component is broken up into various tabs, ie: walls, floors, slab edges etc etc.
Mon, Nov 1, 2004 at 7:42:04 PM | RE: about scheduling
iPang
IWhen I try to open the Excel file there's an error message and the file couldn't be opened. Here's the error message.
Mon, Nov 1, 2004 at 8:37:40 PM | RE: about scheduling
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Interesting. Try this first: Go to File-->Export-->ODBC Database... Where it says DSN Name click NEW. Navigate down to 'Microsoft Excel Driver (*.xls)' Make sure you pick this name exactly. Click NEXT, Now Give it a name, ie Microsoft Excel Click Finish. Now select the DSN you just created and click OK and select the *.xls workbook you wish to export to and click ok. Hopefully this should work.
Mon, Nov 1, 2004 at 9:46:55 PM | RE: about scheduling
iPang
It works!! Thanks alot Mr. Spot. Then.... I have to fill the cost for every family's type? The cost parameter is just appear in family's type not in family right? And I have to link and paste each data to new sheet one by one? I hope it's my last question...Puh
Mon, May 16, 2005 at 10:55:32 AM | RE: about scheduling
KaTorCella
The OBDC output into Excell is an output of the B.I.M. database, correct? The fundamental scheduling of all the building elements within your model is not created simply by outputing ALL the database. Have you been able to use Revit in order to make the quantity take-off you mentioned in your initial query, iPang?
Retaining Curtain Wall Door Scheduling Data
Thu, Jan 8, 2015 at 2:47:08 PM
Wall Scheduling
Mon, Sep 10, 2018 at 8:06:43 AM
SCHEDULING CONDUIT BENDS
Thu, Sep 21, 2017 at 10:06:06 AM
Calculation for Text in Scheduling
Mon, May 30, 2016 at 8:02:21 AM
scheduling structural props of walls or roofs
Sat, Nov 8, 2008 at 12:03:47 PM
Page generation time: 13.6844
