98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> IMport from Archicad
10 Posts No Rating |
I have a consultant in Archicad, I'm in Revit 9.1. Is there a way to impoort his work into mine, and if so how does he need to save his files?
rossdes |
he can export his files out of Archicad as Autocad dwg files which you can then link into Revit
Edited on: Tue, Oct 31, 2006 at 11:10:55 AM
The other option is they could export out of ArchiCAD to IFC. Then in a new revit file you can import the IFC to have it generate the model. This ability is still somewhat limited. At least it was when i last looked at it, but its worth a try. HTH
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
importing from archicad |
Thu, Nov 27, 2008 at 10:55:38 PM
Architect is using ArchiCAD Structural Consultant using Revit? |
Thu, Nov 27, 2008 at 11:23:30 PM
Revit vs. Archicad |
Fri, Sep 28, 2007 at 11:57:54 PM
14
Converting a Revit v 8.0 file into Archicad v10.0 |
Tue, Mar 24, 2009 at 4:21:51 PM
Wish it looks like ArchiCad |
Fri, Nov 28, 2008 at 2:26:55 AM
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
