39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> HOw Do i HidE ThOse Lines ?
Thu, Oct 26, 2006 at 11:49:02 PM | HOw Do i HidE ThOse Lines ?
tharmendra
i created walls from blend (mass). now the floor slab line can be seen in the elevation ! And the wall line can be seen on top of the flat roof (slab). i tried to hide those line using linework(hidden), but...that only works on one view.. any one can help ?
Fri, Oct 27, 2006 at 4:21:04 AM | RE: HOw Do i HidE ThOse Lines ?
nandini
try attaching the walls to the floor. that should help.
Fri, Oct 27, 2006 at 4:23:11 AM | RE: HOw Do i HidE ThOse Lines ?
nandini
and i forgot...if u have created the wall as mass, it will not help. create the wall under modelling create, wall.
Fri, Oct 27, 2006 at 5:16:09 AM | RE: HOw Do i HidE ThOse Lines ?
tharmendra
wow ! most of my wall are all curve sloping wall . that's why i used blend option.
Fri, Oct 27, 2006 at 12:52:43 PM | RE: HOw Do i HidE ThOse Lines ?
ArchWestCY
4.5 Stars: 7 Votes
Can't you just turn your massing into walls and continue from there? I think it will work if you use the Wall by Face tool. Then try the technique that Nandini suggested. Keep in mind that if elements overlap, you will be able to see those lines. Try ending your floor slab inside the walls. ArchWestCY
Mon, Oct 30, 2006 at 9:03:35 PM | HOw Do i HidE ThOse Lines ?
tharmendra
hi. thanks nandini & ArchWestCY.. i got it now..
Structural Deck Floor : What are these lines? How to hide them?
Wed, Feb 17, 2016 at 2:59:34 PM
How do you hide different material joint lines?
Thu, Sep 15, 2011 at 6:53:41 AM
Hide Lines from Void Solid
Wed, Jun 26, 2013 at 3:42:24 PM
Hide Room Separation Lines
Mon, Feb 19, 2018 at 2:03:50 PM
Hide 'Contour' Lines in Modified Sub Element
Tue, Dec 3, 2013 at 9:21:03 AM
Page generation time: 0.6924
