Forums >> Revit Building >> Tips & Tricks >> Walls
21 Posts No Rating |
is there a way to turm certain walls off? like if you are doing a foundation plan with a walk out basement and you want the wood structure walls off so you can see the fnd walls???
![3.5 Stars: 9 Votes](/images/stars_3.5.gif) |
Right click in a view - a 3D view I wouuld prefer .- and choose View Properties.
And in the window Element Properties click on Visibilty´s Edit button
and you can in the new window turn off the visibility of walls.
OK! All walls . not certain walls.
I have not found the possibilty to turn off certain walls - just all in a view...
admin
![hjacobs Avatar](user_avatar/2.jpg)
![3.5 Stars: 16 Votes](/images/stars_3.5.gif) |
You can set up a workset called Foundation Walls or some variation thereof, place all your foundation walls on it, and turn off the workset in the view. Worksets are a great way to control visibility.
Hiroshi Jacobs
The Catholic University of America |
11 Posts No Rating |
If you have the standard tool bar on, there is a button called Hide/Isolate which has a pair of sunglcurse on it. If you activate that command in the view that you would like to hide the walls, or whatever you select to hide. you will notice that the sunglcurse turn red if there is something hidden in your current view.
I hope that it helps. remember that what ever you select will be hidden or isolated in only that view.
1 Posts No Rating |
Another option is to assign all your foundation walls a "bearing" status in the properties box under Structural Usage. Then in the view properties, change the Discipline option to "Sturctural" This should only show bearing walls and structural components. You can modify the view templates to further fine-tune the visibility of certain objects.
7 Posts No Rating |
Is there a way to show foundations drawn normally but represented by dotted lines in a view at the level above i.e. a ground floor plan. I have tried adjusting the zone of visibility to make the footings visiable but I can't seem to find a way to have these displayed in dotted lines.
You can underlay the information you want and then use the linework tool on the elements you wish to show dashed... Then simply turn off your underlay.
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Would Hide/Isolate not work for this? View: Hide/Isolate: select objects you wish to hide, click hide.
Hide/Isolate changes are only temporary and these changes will not print...
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
2nd flr walls not lining up with first floor walls |
Wed, Jun 16, 2010 at 2:20:42 PM
