87 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Showing doors at 45 degrees
Tue, Oct 24, 2006 at 9:05:37 PM | Showing doors at 45 degrees
waltbax
Is there an easy way to show the door swings at45 degrees instead of 90 degrees which is the default angle. It seems I would need to create a whole new family for this. Is that the only way? Any help would be appreciated. Thanks.
Tue, Oct 24, 2006 at 9:51:50 PM | RE: Showing doors at 45 degrees
framerman
4 Stars: 13 Votes
all you need to do is edit the existing door in the family editor in plan view. You don't need to make the whole door family again. Then afterwards you can save it as another family or replace the one with the 90 degree doors
Wed, Oct 25, 2006 at 8:56:50 AM | RE: Showing doors at 45 degrees
winnwg
Hey There is an easy way to show the door swings at 45 degrees or any angle for that matter. Edit the door family. Rotate the shutter a bit so that the door appears open. Set an angular parameter between the shutter and the host ( ie the wall ). Add that parameter to the family type and it will show up when you edit the properties of the door from inside your project. Just change the angle and see the door swing! hope it helps. in case you still have problems, let me know! Regards Winn
Wed, Oct 25, 2006 at 9:01:45 AM | RE: Showing doors at 45 degrees
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
hope this pdf file will helps
Thu, Apr 17, 2008 at 5:10:03 PM | Showing doors at 45 degrees
AbelGoddard
AbelGoddard Avatar
Not so much a 'simple' tutorial. Several things not explained in it for the novice.
Helping you Be Able to be the person you want to be!
Sign up for my free newsletter, Being Able, at http://www.AbelGoddard.com
Thu, Apr 17, 2008 at 8:05:55 PM | Showing doors at 45 degrees
coreed
coreed Avatar
4 Stars: 16 Votes
maybe this give a little more info
http://knowingwhatyoudontknow.blogspot.com/2008/01/adjusting-door-swings.html
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
showing angular dimensions in degrees seconds etc
Wed, May 5, 2004 at 7:43:17 AM
Windows and doors not showing up in walls
Mon, Nov 8, 2010 at 3:24:06 PM
45 degree door swing for Double Doors
Wed, Apr 11, 2007 at 9:56:42 AM
Degrees symbol
Wed, Nov 23, 2005 at 12:33:01 AM
Add rotate parameter by roof pitch not degrees
Tue, Apr 8, 2008 at 4:18:43 PM
Page generation time: 0.7404
