52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how to reduce size of file for archiving
Tue, Oct 24, 2006 at 2:08:11 PM | how to reduce size of file for archiving
TCOOP
Is there a way to reduce the size of the revit file for archiving purposes or even for very large projects. A small project I am working on is already 6mb and is not finished yet. I would like to be able to archive onto DVD's.
Tue, Oct 24, 2006 at 2:35:53 PM | RE: how to reduce size of file for archiving
coreed
coreed Avatar
4 Stars: 16 Votes
you may want to wait until the project is finished. but this was a post from previous form member. i can't remember who it was. i'm sure that are other things you can do, but this will get you started To reduce the file size of your projects 1. Open the file with the Audit option selected. 2. On the File menu, click Purge Unused. 3. In the Purge Unused dialog box, delete all of the definitions not required for your projects. 4..On the File menu, click Manage Links. 5. In the Manage Links dialog box, remove all of the CAD, Revit and DWF files not required for your project. 6. On the File menu, click Raster Images. 7. In the Raster Images dialog box, remove all of the images not required for your project. 8. Save the project with a different name, so the file database can be recompiled HTH Post edited on 2006-10-24 15:14:53
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Revit 2010 - How do I reduce file size?
Wed, Mar 16, 2011 at 10:19:33 AM
When you save as your file. File size reduce automaticly
Fri, Dec 16, 2011 at 9:36:48 AM
How reduce size of BNIM Freight House Flats file?
Wed, May 27, 2009 at 2:59:31 PM
reducing file size
Wed, Oct 11, 2006 at 4:01:49 PM
reducing file size when importing into VIZ 2006
Mon, Apr 3, 2006 at 12:24:34 AM
Page generation time: 2.1002
