44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Elevation Targets
![3 Stars: 2 Votes](/images/stars_3.gif) |
My boss would like for me to put several elevation targets on my building sections indicating where the top of deck is located( it varies due to sloping roof). I can't think of a way to do this other than using levels however it will not let me label more than one level the same, T/ Deck. Any suggestions would be appreciated. Thanks.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Have you tried "spot dimensions" located on the "drafting" tab?
You can play with them to make them look like "level heads", but they can have a prefix/suffix that read consistant like T.O. Deck. They can be used to pick an edge of an object, but if it is sloping I'm not sure you will get a proper result.
HTH
Tom
I did try the spot elevation after I posted my question but it doesn't let me edit the text dimension or move it around.
For those of you who come across the same problem, I was able to make new elevation targets for this purpose. I have up uploaded them to this site so you can download them if needed. I named them Left Elevation Target and Right Elevation Target.
Missing Elevation Targets/Levels |
Thu, Sep 24, 2009 at 12:36:41 PM
Selecting/Finding Specific Level |
Thu, Aug 7, 2014 at 8:33:09 AM
Elevation Callout loading, but can't be used |
Wed, Jul 28, 2010 at 12:48:03 PM
Invert Elevation Vs. Spot Elevation |
Mon, Apr 20, 2015 at 2:09:11 PM
Spot Elevation vs. Level elevation |
Wed, Feb 14, 2018 at 6:13:20 PM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
