102 Users Online (101 Members):
Forums >> Revit Building >> Technical Support >> conical roof generation
One of my students would like to generate a conical roof over a round wall section in his house.
Does REVIT 9.0 have the capability to do this?
If so, can someone point me in the right direction?
Thanks
Easy.
Use Roof by footprint.
Draw a circle and set it to be slope defining
Set it segmentation to 0...
There you go.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Wow, do I feel stupid. I didn't know you could set it to 0. I always made a mass and converted it to a roof.
Thanks again Mr. Spot
hey mr. spot,
do you know if it is possible for the surface pattern
to show when the segments are set to 0?
I always set this with several segments for my pattern
to show
Thanks,
anyone know?
Unfortunately surface patterns will not show on a curved surface in revit.
Post edited on 2006-10-24 22:58:18
Regards,
Chris.
On the subject of "surface patterns will not show on a curved surface in revit." I have had several different experiences where I can see the surface pattern using model patterns on a wall with a raduis but found that when I applied these surface patterns to elements in a sweet it seems to disapear.
Any explanation, please anyone.
Joining a conical roof to a gable roof or other rectangular roof |
Tue, May 28, 2013 at 9:29:25 AM
Conical Roof Framing |
Fri, Feb 22, 2013 at 6:07:12 PM
Revit 2015, Conical Roof Surface Pattern Twist |
Wed, Apr 22, 2015 at 8:57:44 AM
Spiral stairs that follow a conical wall |
Mon, Feb 4, 2008 at 4:46:33 PM
Pat file generation |
Mon, Aug 26, 2013 at 2:17:43 AM
Members: | 2056329 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
