77 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> Different visibility settings in the same view
6 Posts No Rating |
Does anyone know that Is there any way that I can control different visibility settings in the same view.
like plan region can isolate different areas and have different view ranges??????
PLEASE LET ME KNOW IF YOU KNOWS
THANKS
What do you mean? I'm not sure what you're attempting to do?
By the sounds of things Filters are what you need, but it will depend on what exactly your trying to achieve to whether you need to use them or not.
Regards,
Chris.
6 Posts No Rating |
Thank you for your prompt response, i am sorry that i didn't describe the situation clear earlier.
what i trying to do is that i have some toilets in the plan that i want to show but at the same time i have some sinks that i don't want to show in the document, and two objects are plumbing fixtures, so when i turn off plumbing fixture in visibility dialog. both of them turn off. and i can't change the truth that they are all plumbing fixtures. so i wonder that is there anyway i can isolate the bathroom area so i can show toilets and turn off plumbing fixture for the rest of the area? if you can help me, i will very very appreciate it. thank you very much
Post edited on 2006-10-20 08:14:14
Two methods:
1. Edit the families and place the model elements in a subcategory of the plumbing fixtures. This way you can turn off the subcategories only.
2. Create a filter in the project. Use settings like:
Filter-->Plumbing Fixtures-->Type Name does not contain Toilets... Will depending on how your files are named (they are case sensitive)
HTH.
Sorry for the delay. Been flat out lately.
Regards,
Chris.
Saving View Visibility Settings |
Mon, Aug 28, 2006 at 9:33:20 AM
Family element Visibility Settings |
Tue, Jun 11, 2013 at 4:08:30 AM
How do we retain visibility graphics settings for our consultant files? |
Thu, Mar 12, 2015 at 2:18:49 PM
Locking visibility settings in sheets |
Fri, May 18, 2007 at 5:00:49 PM
Sections not Showing in Plan View |
Mon, Oct 28, 2019 at 4:42:02 PM
Members: | 2016968 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
