Forums >> Revit Building >> Technical Support >> Toposurface creation using numerical data.
24 Posts No Rating |
I received a list of coordinates and heights from a surveyor. I understand that Revit has the capacity to create a toposurface from such data. Does anybody know how?
58 Posts No Rating |
from the ACad file create a 'csv' file. load it into the Revit file and then select when doing the toposurface..
I received the data in a ASC format and can only open it in a text editor.
It is a list of numerical coordinates (see attached file at original post)
The local distributors of Revit are at a loss…so, how does one do this?
Once the ASC is opened in MS WordPad, how would one create a CSV file?
If I am going about this all wrong, I’d appreciate some alterative advice.
4 Posts No Rating |
Attached You will find a csv-file with Your data in it. I opened it in excel, stripped off unwanted data and then saved it as a csv-file.
Now You just have to open Revit and choose "toposurface - use imported - points file" and select the csv-file. For more info on this look at this excellent page: http://revitrocks.blogspot.com/2006/07/importing-topo-points-into-revit.html
BG
Patrik from Sweden
hey, first thing you should do is relax...
there are two ways of creating a toposurface...one by importing a Acad file which has the contour lines with their elevations or which have the z value...the second is by taking the csv file from Acad file(in situations which have the co-ordinate values and no contour lines).
By how much i know, revit identifies just these two formats.
the ASC file you have can be converted to a CSV format...open it in notepad and convert it...
you can think of solutions by being calm and believing that the solution exists...
good luck!
Brilliant…Thanks guys.
Using Survey Data to create a toposurface |
Mon, Oct 4, 2010 at 2:23:29 PM
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:50 AM
Create Toposurface |
Wed, Apr 22, 2009 at 5:06:54 AM
toposurface data import/positioning |
Fri, Dec 21, 2012 at 6:45:25 AM
Entering numerical value for angle at setting out? |
Sun, Feb 22, 2009 at 11:48:24 PM
Members: | 2101411 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
