82 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> adding textures to wall
Tue, Oct 17, 2006 at 7:21:46 PM | adding textures to wall
rohit
1 Stars: 1 Votes
Can I add textures to walls such as bricks after I finish the building? This is probably a stupid question, but I am new to Revit. Also, can someone please tell me how to add these textures to walls
Tue, Oct 17, 2006 at 9:27:47 PM | RE: adding textures to wall
hisdirt
5 Stars: 5 Votes
Hey rohit, There are a couple of different ways to do this, either by editing the wall type and altering the material of the interior/exterior layer - or using the 'paint' tool and painting the wall face you'd like in the material you'd like. I'd suggest the first method because as one material change will go through your whole model and change every wall for you. The 'paint' tool should only be used in exceptional circumstances, and only really for apperances sake - hence the name. Hope this helps!
free hi res textures
Mon, Apr 13, 2009 at 2:47:30 AM
Revit render textures - any good resources on the web?
Thu, Dec 16, 2010 at 10:54:16 AM
High Res Textures for Rendering
Fri, Apr 17, 2009 at 12:15:30 PM
ADD TEXTURES AND HATCHS
Wed, May 6, 2009 at 7:59:51 AM
alucobond materials and textures
Tue, Jan 28, 2014 at 7:33:51 AM
Page generation time: 1.3850
