67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> HORRIBLE PERFORMANCE
Wed, Oct 27, 2004 at 3:55:22 PM | HORRIBLE PERFORMANCE
neb1998
Revit 7 May have new features but its starting to act like windows 3.1. After 20 min of use the entire program crawls to a hault. Why do properties windows take 5 seconds to load now? Why when changing view preferences (furniture on, furniture off) take more time then rendering a small scene? I do not know, someone at autodesk did not do their homework? Autodesk the new Microsoft? You be the judge.
Wed, Oct 27, 2004 at 4:07:21 PM | RE: HORRIBLE PERFORMANCE
maxlloyd
4 Stars: 9 Votes
agreed, seems very slow doing simple things.
Wed, Oct 27, 2004 at 4:51:28 PM | RE: HORRIBLE PERFORMANCE
Redrose
I haven't got 7 yet, but if it gets quicker if you exit and restart Revit then I suspect the dreaded Memory Leak has reared its head. Bring up the Task Manager and keep an eye on the process's memory usage. If it keeps going up without ever dropping significantly then I would suspect the worst. I hop enot though, because you'd expect the s/w engineers to have checked it before they release it(!!!)
Tue, Nov 23, 2004 at 8:24:15 PM | RE: HORRIBLE PERFORMANCE
jknr
Only download latest version: Revit7.0_20041113_2030.exe. There is no slowdown after a while in this compilation. PS: Redrose was right.
Thu, Dec 9, 2004 at 11:14:07 PM | RE: HORRIBLE PERFORMANCE
WATTSAIA
I have heard at AU the first download version of 7.0 has a memory leak, which eventually fills up all of your RAM but has been fixed ....
Tops of the walls applied to mass looks horrible
Mon, Jan 5, 2015 at 10:45:47 AM
Slow Model? – How to Increase Revit Performance
Thu, May 23, 2013 at 2:22:22 PM
Posted Performance of Currently used/tested Revit Systems
Wed, Apr 21, 2010 at 9:35:29 AM
12
Revit 2013 slow performance in citrix
Wed, Nov 5, 2014 at 11:03:13 AM
PERFORMANCE RELATED TO MOUSE
Fri, Feb 9, 2007 at 2:34:04 PM
Page generation time: 1.0717
