Forums >> Revit Building >> Technical Support >> Linked Revit Files exported to dwg
Mon, Oct 16, 2006 at 2:42:19 PM | Linked Revit Files exported to dwg
superelboogie
Hi ok so my doors and windows are not showing up on my linked file when i export my revit file or print from revit. ive adjusted all the settings trying to make them show up. They are there on my screen. and the first floor windows and doors are just fine. the settings are the same as the second floor, but they are just not printing or exporting. Actually parts of a few of the windows show up.... very strange! I need help ASAP! Smile
Wed, Oct 18, 2006 at 9:59:41 PM | RE: Linked Revit Files exported to dwg
trich00
Check your exporting setings to make sure all the elements in you windows and doors are assigned to a layer - One thing I have found is if you export to DWG in "wireframe" families / line etc that overlap do not cut out other objects that may be under them. This may be casuing things to look "cut out" Also as our standard we usually create a view just for exporting so we are not alwyas chanign the view properties.
Exporting issues... exported dwg files missing information
Thu, Jan 24, 2008 at 11:43:21 AM
Linked DWG Files not visable in RCP
Mon, Oct 19, 2009 at 1:46:58 PM
Overlays in Linked .dwg Files Showing Up in Revit 2013 Views
Wed, Sep 26, 2012 at 9:22:01 AM
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:43 AM
Page generation time: 7.5157
