46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Form-Z to Revit and Revit to Form-z
5 Posts No Rating |
What are, if any, the translation process between Form-Z and Revit?
Is this possible?
![cholden Avatar](user_avatar/36740.jpg)
37 Posts No Rating |
Did you ever find any solutions or answers to this issue?
32 Posts No Rating |
I have sucessfuly exported to Form-Z 1. export via FBX using all of the default settings. 2. import FBX to 3ds Max using defaults (be sure to have the FBX patch installed) 3. export to 3ds format (use default here as well maybe save down as an older version to help with compatibility) 4. import 3ds to Form-Z All materials will be present and all geometry will be there. Untill From-Z is FBX ready (they have no plans to do this see their web site) this is the only path I have found. Its better to model in the massing feature in revit! Good Luck
add edge to top of form |
Fri, Jun 25, 2010 at 8:58:21 AM
void form and cuttng void form |
Fri, Jul 9, 2010 at 12:39:02 PM
Creating a special form - walls, roof and floors |
Sun, Mar 29, 2009 at 8:42:58 AM
aligning two curtain walls/panels in a Blob-like form |
Wed, Jan 22, 2014 at 1:39:53 AM
Revit 2010 Is Driving me MAD !!!Making Mass with FORM tool is ..confusing me!!!! |
Fri, Oct 23, 2009 at 9:10:09 AM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
