73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Schedule walls by floor
Wed, Oct 11, 2006 at 5:24:03 PM | Schedule walls by floor
SteveB
3.5 Stars: 5 Votes
Would there be a way to have a schedule report walls by floor? Would there be a way to add a field or parameter to all walls (not each wall family one by one) that I could just select all walls on a plan and add a note 1flr, 2 flr, etc then sort by that?
Wed, Oct 11, 2006 at 5:52:02 PM | RE: Schedule walls by floor
ArchWestCY
4.5 Stars: 7 Votes
In the Field tab of your schedule properties, add the Level Perameter. Then, in the Filter tab you can filter by Level. if you don't want the Level Column to show up in your schedule you can go to the Formatting tab and click the Hidden Field check box. ArchWestCY
Wed, Oct 11, 2006 at 5:58:42 PM | RE: Schedule walls by floor
SteveB
3.5 Stars: 5 Votes
Excellent, Thanks! I am developing a quatity takeoff tool to help put together lumber lists, sorted by delivery (by level). I'll see how it works out compared to estimators "by hand" takeoff and report back.
Tue, Jan 2, 2007 at 4:13:31 PM | Schedule walls by floor
HegsethHomes
I am trying to create a similar material takeoff system. Did you have any luck with yours.
demo walls schedule
Wed, Mar 30, 2005 at 6:40:28 PM
Multicategory Schedule Problem-Walls
Thu, Sep 4, 2008 at 9:46:25 AM
Schedule curtain panel by level?
Fri, Sep 2, 2016 at 4:40:26 PM
Cut floor around walls
Fri, May 24, 2013 at 12:09:37 PM
floor volumes schedule
Tue, Dec 8, 2009 at 3:24:24 AM
Page generation time: 0.8387
