80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> reducing file size
Wed, Oct 11, 2006 at 3:31:17 PM | reducing file size
architurk
architurk Avatar
3.5 Stars: 3 Votes
in order to mail a rvt file to a friend i have erased the irrelevant parts of the drawing but the size remained almost the same. i have also done "purge unused", i have adviced to get rid of links and open the file while "audit" is checked. but almost nothing changed. is there any other way to reduce the size?
Wed, Oct 11, 2006 at 3:43:11 PM | RE: reducing file size
framerman
4 Stars: 13 Votes
Try Save As..then under options click compact file(slow). Never tried it though so be careful. The only other thing I can think of is to open up your family tree and manually delete stuf you don't need. I'm not sure if you did that already. File size I believe is probably going to be somewhere between 10mb-20mb. The ones I have usually are around 50mb's. Post edited on 2006-10-11 15:45:58
Wed, Oct 11, 2006 at 4:01:48 PM | RE: reducing file size
architurk
architurk Avatar
3.5 Stars: 3 Votes
thx esp "compact file (slow)" thing seems to work much!
reducing file size when importing into VIZ 2006
Mon, Apr 3, 2006 at 12:24:33 AM
Reducing File Size
Thu, Sep 22, 2005 at 6:52:53 PM
Having difficulty reducing file size to less than 400mb!
Fri, Nov 19, 2010 at 10:12:59 AM
'save as' reduces file size - a good method?
Tue, Sep 23, 2014 at 7:36:45 AM
Reducing elevation tag size
Fri, Mar 7, 2008 at 11:56:12 AM
Page generation time: 1.2503
