81 Users Online (80 Members):
Forums >> Revit Building >> Technical Support >> curse root
14 Posts No Rating |
i'm working on an irregular perimeter roof, no way to design as i want it... see .pdf
please help
Post edited on 2006-10-11 10:15:09
Instead of creating it as one roof make each plane a single roof. This may take some time to do it but you will be able to achive what you want.
well, from what I see, you cannot make it separate planes and this is why: your span on your roof is not parallel with each other and you'd like to have the same ridge line to make it level wih the world. What I see is that you are going to have a twisted roof face on the two sides. You will end up with, say, a 6/12 on one end and a 12/12 on the other (I'm obviously just making those numbers up)
I have seen it in the documentation that comes with Revit, but for some reason I can't seem to locate it. I'm thinking it's a mass>blend command. Or if you have the capabilities of another program, a nurb surface will do it too. Sorry I couldn't be more help.
58 Posts No Rating |
what could be done is make the roof as a full rectangle so that the ridge is parallel to the horizontal plane (level plane)...then, take of the un necessary segment by making it as a roof opening...
try it, this should work.
curse hip |
Sun, Dec 14, 2008 at 4:16:22 AM
roof curse tags |
Thu, Aug 9, 2007 at 12:42:47 AM
Simple Question? : Load curse'y views into Project... |
Tue, Feb 18, 2014 at 12:41:01 PM
curtain panel glass type |
Thu, Dec 11, 2008 at 3:25:26 PM
curse, i can't post comments on downloads and gallery section?? |
Sun, Jul 26, 2009 at 9:14:39 AM
Members: | 2030542 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
