71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> help! slow color printing???
Mon, Oct 9, 2006 at 4:12:45 PM | help! slow color printing???
sweetiedarling
Anyone experienced this problem? The color printing is very slow from Revit; it seems to spool huge files, and seems to take a very long time to spool. A 30x42 board of elevations with color and shadow created a 160mb+ file in the printer. Any suggestions would be greatly appreciated!
Tue, Mar 6, 2007 at 2:42:59 PM | help! slow color printing???
derxaj
3.5 Stars: 3 Votes
Hey...yah see the problem is that when creating any images with advanced graphic mode (shadows, color, all the good stuff) Revit has to rasterize the images first (since vector processing cant be used) and then send the images to your printer in the same operation.  Depending on how fast your machines are, and even with a quick machine, more then likely this will take awhile.  I know we have a grayscale image on one of our drawings with shadows turned on and it takes quite a few minutes to rasterize and then print.
 Possibly the easiest solution I can think of is it write the image to a PDF or DWF first, and then send the PDF to the printer.  The files shouldnt be near 160mb when sent to the printer after that.  Try that and see if it helps at all.
 Adam
Wed, Feb 26, 2014 at 4:27:15 PM | help! slow color printing???
mhaworks
Great response. It has taken me several searches and several weeks of frustration to realize this was happening and to unclick rasterize on my printer driver. I used to rasterize everyting when I printed from Revit 2012 (just a bad habiot formed from color printing with hatches) and it was never a problem so naturally, this was not the first place I checked. Thank you!!!!
Fri, Feb 28, 2014 at 10:03:57 PM | help! slow color printing???
Warchitect
4 Stars: 5 Votes
Also, when printing to PDF. when you are in the print window, under Print setup, set the "raster quality" option to medium. This is what I do. (am architect) and you get about 1 meg files that are pretty decent in terms of "architecturalness"
I bet yours is set to "presentation"
give that a try and see if you like it. I bet you will.
Warc.
PRINTING COLOR HATCH TO BLACK
Tue, Aug 16, 2011 at 1:59:52 PM
Printing issues
Thu, Nov 4, 2010 at 7:32:11 AM
Problems printing to HP 1055
Thu, Dec 6, 2012 at 8:54:54 AM
Room Color Fill Not Printing, Random Circle is
Wed, May 17, 2006 at 6:20:12 AM
color selection and printing
Mon, Aug 22, 2005 at 11:39:45 AM
Page generation time: 0.8392
