73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Granite countertops
Mon, Oct 9, 2006 at 6:51:46 AM | Granite countertops
daudesign2
I am trying to make granite countertops. I tried a solid extrusion, but it doesn't accept assigned materials. How can I do this and put in a sink hole?
Mon, Oct 9, 2006 at 7:25:57 AM | RE: Granite countertops
akccrox
You can put in the sink hole by either using a void extrusion or by editing the solid extrusion to extrude around the sink. As for the material question i have the same problems when creating the family outside of a project.
Mon, Oct 9, 2006 at 8:42:20 AM | RE: Granite countertops
Jerome111
3 Stars: 2 Votes
creating a "floor" for your countertops work well.... you can set the height of the countertop "floor" 3ft above your level, (set your thickness). You can asign a material type to it and use the "opening" fearture under the modeling tab to create the openings for sinks.
Tue, Oct 10, 2006 at 6:14:31 AM | RE: Granite countertops
daudesign2
Thanks for the help.
Does anyone has a granite texture??
Tue, Apr 11, 2006 at 11:31:16 AM
Invisible Countertops
Fri, Mar 14, 2008 at 10:43:15 AM
Countertops
Wed, Sep 21, 2005 at 5:58:21 PM
Scheduling Countertops
Tue, Sep 20, 2005 at 9:33:36 AM
Scheduling Mass Objects (countertops)
Tue, Sep 20, 2005 at 9:17:49 AM
Page generation time: 0.1712
