45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> swimming pool
Sat, Oct 7, 2006 at 8:45:10 AM | swimming pool
daudesign2
How do I cut the toposurface and build a swimming pool?
Wed, Oct 11, 2006 at 12:42:46 PM | RE: swimming pool
framerman
4 Stars: 13 Votes
I don't know much about toposurfaces, but I tried a little sample. This is what I did. I used split surface from the site menu. I made a rectangle, then I pressed delete on my keyboard and now I have a hole in my toposurface. Don't really know if this is the most elegant way to do it, but it worked.
Wed, Oct 11, 2006 at 1:14:34 PM | RE: swimming pool
JHanby
3.5 Stars: 3 Votes
http://www.revitcity.com/forums.php?action=viewthread&thread_id=2133#6794
Jill
Wed, Oct 11, 2006 at 6:12:48 PM | RE: swimming pool
geoffy
Here is a simple way if you have a "flat" toposurface- use a Pad to create the shape of the pool you require and then apply the site - water material to it then a little bit of a path or tiles around that and there you have a simple way of indicating a pool on your site plan. Hope this helps
AutoCAD & Revit TAFE teacher from regional Australia
Wed, Oct 18, 2006 at 1:31:34 PM | RE: swimming pool
Tuddy1976
weres the picture Post edited on 2006-10-18 13:32:06
Wed, Sep 15, 2010 at 12:54:01 AM | swimming pool
ChokeSlam
I think you have to be specific with this one. Can you give us a picture or a sketch?
cover above ground|| winter pool cover
How to make a Swimming Pool?
Wed, Sep 28, 2016 at 1:23:05 AM
Swimming Pool
Tue, Dec 8, 2009 at 4:11:28 AM
Swimming Pool
Tue, Jun 28, 2016 at 9:04:19 PM
Swimming Pool
Mon, Jan 28, 2013 at 7:44:57 AM
Swimming Pool?
Mon, Sep 20, 2010 at 12:24:42 AM
Page generation time: 0.2011
