131 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> multiple detail tags for same detail
Fri, Oct 6, 2006 at 10:27:35 AM | multiple detail tags for same detail
scaledup
Is there a way to put multiple tags on a drafting view that refer to the same detail? For example for different windows that have certain details that are the same.
Fri, Oct 6, 2006 at 10:53:34 AM | RE: multiple detail tags for same detail
jfurlong
if i get you right it is possible. sorry just before that you will get a better response if you post to the correct forum you should put a question like this in the technical issues form creat a new drafting(Draft1) view and name it create a section of the arae of the window you want place a callout detail view and name it place any of you detail lines ect in this view. now in your drafing view(Draft1) or plan ect. use callout choose the refference other view and choose the callout that you created above (Call1) repeat the last step. you should now have what you are after. hope this helps.
Fri, Oct 6, 2006 at 11:05:09 AM | RE: multiple detail tags for same detail
scaledup
Thanks. First time posting...will try to post in the correct place in the future.
additional detail tags
Thu, Apr 19, 2012 at 3:27:32 PM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:09:25 AM
Hiding Detail Tags in other views [ 1 2 ]
Thu, Jan 21, 2010 at 5:26:48 PM
21
Detail tags
Tue, Feb 11, 2014 at 10:10:28 AM
Multiple referances to the same detail
Fri, Jan 20, 2006 at 1:50:54 PM
Page generation time: 0.6914
