49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Fill Region not visable
Thu, Oct 5, 2006 at 3:46:48 PM | Fill Region not visable
Poppy1977
Sometimes my Fill Regions show up just fine and sometimes they don't. It seams to depend on which pattern I use. The flagstone pat. file I'm trying to use is not showing and that's the one I'm wanting to use. It shows up just fine when used as flooring, but not Fill Regions. When I select the Fill Region the pattern shows up just fine. Help! Thanks in advance, Poppy
Thu, Oct 5, 2006 at 4:12:10 PM | RE: Fill Region not visable
Poppy1977
Sorry, never mind, I figured it out. When editing Fill Regions, it is helpful to select a color other than white if you want them to show up on a white background. Poppy
How to I have a fill region or masking region and have my CAD import over it?
Tue, Oct 20, 2015 at 1:09:06 PM
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Unable to select the fill region
Mon, Aug 13, 2012 at 3:51:58 PM
different fill pattern for multi fill region in the same view?
Wed, Jun 13, 2012 at 4:33:27 PM
Fill Region Not Showing
Wed, Aug 22, 2018 at 5:28:47 PM
Page generation time: 4.7879
