105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 2d drafting details
Thu, Oct 5, 2006 at 10:28:16 AM | 2d drafting details
Jerome111
3 Stars: 2 Votes
I have created several 2d drafting details in revit that I would like to insert into the drawing set. and key them on the plan.... how do I do that?
Thu, Oct 5, 2006 at 10:59:03 AM | RE: 2d drafting details
Jerome111
3 Stars: 2 Votes
Attached is the rfa file.. the text will not display when inserted into a project. only the line work
Thu, Oct 5, 2006 at 11:19:55 AM | RE: 2d drafting details
rkitect
rkitect Avatar
4 Stars: 29 Votes
Jerome, Here is what I found. I couldn't find anything that would allow the text from the detail family to show up in the project. So what I did is placed the detail component into the project, then copied the text and dimensions seperately into the view with the detail component. I know that sucks.. but that's the only way I got it to work. If anyone else has a better way to do this, please let us know. Thanks and best of luck!
Thu, Oct 5, 2006 at 4:34:01 PM | RE: 2d drafting details
laurabh
To confirm what rkitect said, text drawn in a detail component in the family editor cannot appear in a project file when inserted into the project. Sorry that I don't know a better way to do it.
Thu, Oct 5, 2006 at 5:13:18 PM | RE: 2d drafting details
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You need to make use of Revits detail library. Once you've got the view setup the way you want you can save the view out as its own file for later use in another project. HTH.
Regards,
Chris.
Drafting Details - Detail Components vs Groups
Sun, Nov 13, 2005 at 5:56:12 PM
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
drafting details
Fri, Feb 19, 2010 at 7:08:37 AM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Drafting view
Thu, Aug 6, 2015 at 1:41:00 PM
Page generation time: 0.3978
