105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Line style changes in phases - how do I maintain the properties of a line?
Thu, Oct 5, 2006 at 9:04:06 AM | Line style changes in phases - how do I maintain the properties of a line?
altlore
I've created scope of work lines using the line style setting. Unfortunately, the lines are recognized as constructed elements rather than annotations. The result of this issue is that they become existing (changing the line appearance) and do not show up at all in the demolition drawings for the appropriate phases. Is there a way to maintain the properties/appearance no matter what phase or drawing it appears in? Is there a way to make these lines into annotation lines rather than "constructed" lines? Any advice would be greatly appreciated...
Thu, Oct 5, 2006 at 9:51:55 AM | RE: Line style changes in phases - how do I maintain the properties of a line?
altlore
My Bad... I was using model lines (which are affected by phases) rather than detail lines which are not affected by phases. Thanks to Revit Support for answering that question... and very quickly I might add.
Object Style over rides per phases
Mon, Feb 21, 2011 at 5:18:42 PM
line style in plan view
Thu, Mar 4, 2004 at 12:47:43 PM
Manage Line Style of a Door
Wed, Jan 6, 2010 at 4:33:26 PM
Any Suggestions For Line wt Table set up and Line Style Names
Thu, Jun 5, 2008 at 7:01:45 AM
Line Style is acting up, showing wrong line property
Sun, Aug 21, 2016 at 11:07:44 AM
Page generation time: 0.9045
