54 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> How do I create a scope-of-work line
7 Posts No Rating |
I am currently working on a multi-phase project in a large existing hospital. I need to place scope-of-work lines around the work areas in each phase so that people looking at the rather complex drawings can quickly locate the areas where changes are occuring.
I've tried to place a dotted line around the work areas and then change the lineweight to a very heavy line (scaled 4" in the drawing). Unfortunately, I have been unsuccessful in my attempts to increase the size of the lines.
Can anyone help me with this? Is there an easy solution to scope-of-work lines that I'm overlooking? Please help... I have a deadline and bosses to answer to...and I'm the only person in my office who knows anything about Revit.
7 Posts No Rating |
I found the answer to this so I'll share it. It was more simple than I thought it would be...
Under Settings, select Linestyles.
Create a new linestyle & set the properties...
I hope this helps others.
scope of work on workstation |
Mon, Feb 25, 2013 at 11:37:49 AM
Scope box not visible |
Thu, Oct 19, 2017 at 12:33:04 PM
Scope Box Datum Control |
Fri, Apr 21, 2006 at 6:57:15 PM
Make Scope Box Visible after all Views Hidden |
Tue, Oct 25, 2016 at 4:40:46 PM
Grid Bubbles relative to scope box. |
Tue, Jul 10, 2007 at 4:20:50 PM
Members: | 2019273 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
