110 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> Worksets >> worksets by floor
Wed, Oct 4, 2006 at 11:15:09 AM | worksets by floor
bigstein
Hi Has anyone done worksets by floor levels? BS
Wed, Oct 4, 2006 at 6:45:17 PM | RE: worksets by floor
eldados
eldados Avatar
4.5 Stars: 8 Votes
the question is WHY? why would you want to do that? is it so you can have people working on a floor at a time? this is not a smart solution. first, you won't have one guy looking after all the different building element on one floor, but someone looking at ONE element through the project. second, you start to get away from how Revit works and that will create more problems down the line... now that 9 does not need to ask for permission it is much easier with worksets. i suggest you break dow your worksets to building elements. HTH
Integrator
KarelCAD
Wed, Nov 8, 2006 at 11:28:08 AM | worksets by floor
rodells
I wish I had read Eldados' response here a few months ago.   I sorted a project by level, and created so many problems that now no one wants to even use worksets even though we are worksharing.
The advice to sort by elements seems obvious in hindsight, but I think it takes some experience to understand how to use many tools in Revit to their best advantage, especially if coming from years of CAD production background...
Wed, Feb 21, 2007 at 6:39:10 AM | worksets by floor
xiqx
Question what if you are working on 1 building with several people. The first 3 floors are different from eachother. then you have 10 floors who a nearly identical. and then you have two top floors that are different again.
How would you approach this if you would want to work on this with 3 people. (construction is set) facades are not.
Wed, Feb 21, 2007 at 4:41:14 PM | worksets by floor
eldados
eldados Avatar
4.5 Stars: 8 Votes
I would still break it to it's elements, you don't want 3 guys doing the same amenities on different floors.
there will be one person doing the facade, other might look at setout and dimensions and so on... it is better for a person to do one thing throughout the project, that's better for quality control...
Integrator
KarelCAD
Mon, Mar 5, 2007 at 10:03:46 AM | worksets by floor
mfkkd
Here's a question.  What if you were trying to work with a contractor who is using the model for BIM estimating? Meaning they would like the model organized according to their estimating breakouts.  Could the model be organized by uniformat level 2?
Tue, May 20, 2008 at 4:55:39 PM | worksets by floor
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
You could yes but it would take a long time and probably provide more problems than it would be good for. I have sucessfully set up an arch model up and created it with worksets per floor so that i am able to coordinate in Navis for an unnamed contractor. we are also doing the mep/fp the same way.
http://familyjewels.typepad.com/
Worksets
Fri, Feb 25, 2005 at 11:34:30 AM
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
Wed, Feb 1, 2012 at 5:04:15 PM
Worksets question - standards question...
Wed, Oct 21, 2009 at 7:28:40 AM
Page generation time: 1.8666
