102 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How do I delete an Acoustic Ceilng?
Wed, Oct 4, 2006 at 10:56:26 AM | How do I delete an Acoustic Ceilng?
6slinger
1 Stars: 1 Votes
Hi New to Revit, and I am creating a ceiling to show what the exisiting building looks like right now. The ceiling should be half 2x4 and half 2x2. It is all 2x4 and I cannot figure out how to delete the ceiling and correct it. Thank you in advance. Kirk Post edited on 2006-10-04 10:56:48
Wed, Oct 4, 2006 at 11:11:49 AM | RE: How do I delete an Acoustic Ceilng?
jfurlong
easiest way to delete your ceiling is to draw a section through your model select the ceiling and hit delete on your keyboard if you want to place 2 different ceilings in the one room, choose ceiling sketch option on your properties bar sketch first ceilng then do the same for the second one.
Wed, Oct 4, 2006 at 12:18:50 PM | RE: How do I delete an Acoustic Ceilng?
6slinger
1 Stars: 1 Votes
Thank you very much. Kirk
Wed, Oct 4, 2006 at 1:30:29 PM | RE: How do I delete an Acoustic Ceilng?
stevelj
Or use the TAB key near a wall/ceiling intersection, works great!
Acoustic/Fire Barriers
Mon, Feb 4, 2013 at 11:22:06 AM
making acoustic ceilings
Thu, May 6, 2010 at 11:38:21 AM
acoustic wooden cloud ceiling
Fri, May 15, 2015 at 1:46:02 PM
How to delete Title Blocks
Thu, Feb 28, 2013 at 9:34:03 AM
WALL HATCH PATTERNS IN REFLECTED CEILNG PLANS 2009
Fri, Aug 29, 2008 at 10:01:31 AM
Page generation time: 2.7217
