37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Shadow export
Wed, Oct 4, 2006 at 8:13:06 AM | Shadow export
SteveB
3.5 Stars: 5 Votes
Is there a way to export a shodow study (advanced model graphics->cast shadows) from revit into autocad. I was hoping to have the shadow turn into a hatch pattern, can't seem to make it work. Exporting it as an image doesn't help.
Wed, Oct 4, 2006 at 9:25:52 AM | RE: Shadow export
rkitect
rkitect Avatar
4 Stars: 29 Votes
Sorry Steve, I'm seeing nothing that will do this Sad
Wed, Oct 4, 2006 at 11:24:13 AM | RE: Shadow export
jfurlong
create a new type of filled region called shadow in ithe filled regions properties change its surface pattern to solid fill and give it a colour say magenta trace over your shadow export to dwg you should now have a hatch where your shadow was.
Wed, Oct 4, 2006 at 2:38:51 PM | RE: Shadow export
SteveB
3.5 Stars: 5 Votes
that puts the "work" in "work-around"! I decided to import the autocad site plan into revit and let revit cast the shadows.
Shadow Casting
Thu, Feb 12, 2009 at 10:00:49 PM
Doors make a gray shadow in Sections
Wed, Apr 7, 2004 at 10:39:44 AM
Drawing won't export with shadows on
Fri, May 10, 2013 at 12:18:39 PM
Need to show shadow of canopy on ground
Mon, Dec 26, 2016 at 12:30:36 AM
Shadow is not visible when rendering
Wed, Mar 19, 2008 at 11:23:55 AM
Page generation time: 0.2968
