59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> MATERIAL ASSIGNMENT
How do I assign JPEG'S to a surface?
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
2 ways:
1) If you want to use it as a decal (like for a painting or a tv screen):
-Modeling >> Decal
-Pick the JPG you want to use and then place it where you want it (read the help file on Decals)
2) If you want to use the JPG as a material (ie: brick, conc, grass, etc.)
-Settings >> Materials
-Click a material in the 'Name' column that is similar to your material and cuplicate it. If nothing is even remotely close then just duplicate any material.
-In the 'AccuRender' box, click the little return arrow to the right of the texture box.
-right click a material in the 'Name' column and select New > Default Gray
-To apply the JPG go to the 'Maps' tab and add a new map (under image mapping), browse to your JPG. Voila.
Look at other materials to see how they acheived different looks, this is just the tip of the iceburg. Hope it helped
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
![hammer87 Avatar](user_avatar/10984.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
i didnt know about the decal feature, is this in version 8 or 9?
Decal has been around since 6 I believe.
material assignment problems |
Fri, Oct 13, 2006 at 8:13:10 AM
Material Update Confusing |
Sat, Jul 26, 2008 at 7:50:28 PM
material assignment glitch |
Thu, Jan 21, 2016 at 1:42:10 PM
Possible for an object to rotate a material? |
Thu, Sep 2, 2010 at 8:22:46 AM
Change family color in model |
Fri, Nov 10, 2017 at 9:01:44 AM
Members: | 2026209 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
