130 Users Online (127 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Trouble w/ interior elevation tags
Tue, Oct 3, 2006 at 1:44:09 PM | Trouble w/ interior elevation tags
bigstein
Hi All I am having trouble trying to figure out how to turn off the 'names' of interior elevations that automatically come in with the tags when you place them. Where can I do this? Thanks BS
Tue, Oct 3, 2006 at 3:47:50 PM | RE: Trouble w/ interior elevation tags
TomDorner
4.5 Stars: 25 Votes
They are controlled at: Settings>View Tags>Elevation Tags Then pick your elevation type and change "show view name" to be unticked Tom
Tue, Oct 3, 2006 at 3:53:11 PM | RE: Trouble w/ interior elevation tags
bigstein
Thank you - I knew it had to be something simple like that. Are you working at all with linked models? I am trying to find a way to display the section tags and other annotations from the linked model so that when I print a plan sheet I see all of the information. BS
Thu, Jun 28, 2007 at 8:25:41 AM | Trouble w/ interior elevation tags
immererin
I love when I search for an answer and I find it immediately!  Thanks!
Mon, Jan 4, 2010 at 2:43:17 PM | Trouble w/ interior elevation tags
rltaylor3
rltaylor3 Avatar
Can anyone answer this question for R2010, which has not a "settings menu"?
Mon, Jan 4, 2010 at 2:50:10 PM | Trouble w/ interior elevation tags
rltaylor3
rltaylor3 Avatar
Sorry, it took me a bit longer to find the Setting menu under "Manage".
...But sure enough, there it is!
problem solved
Interior Elevation Tags
Wed, Oct 9, 2013 at 2:23:36 PM
2011 interior elevation tags
Thu, Dec 23, 2010 at 11:44:57 AM
Scaling Interior Elevation Tags
Fri, Mar 3, 2006 at 3:07:26 AM
Interior Elevation Tags in Detail Plan Views
Tue, Nov 9, 2010 at 8:06:17 AM
Similar Tags - Interior Elevation
Fri, Oct 24, 2008 at 10:32:16 AM
Page generation time: 1.4364
