Forums >> Revit Building >> Technical Support >> Interior and Exterior Doors
11 Posts No Rating |
I need to export Revit files to AutoCAD DWG's to match specific client standards. Does anyone know of any way to specify between interior and exterior doors in Revit. So, when I export to AutoCAD they will be on different layers.
Thank you,
Matt Coffey
You can try creating a subcategory (either interior or exterior or both) under doors. Then under File >> Import/Export Settings, you can set up how the doors will export to DWG.
HTH.
I tried that. It still will only export the doors to the same layer. I think I'd need to create a family for interior and exterior doors and somehow specify in the family if they are interior or exterior. I just haven't figured out how to do that yet. Thanks for your suggestion though.
Take a look at this family (assuming you are using Revit 9). I added some subcategories to to the family (while in family editor, Settings >> Object Styles), then selected the Panel extrusion of the door and placed it in the subcategory 'Interior - Panel' for instance. You do this for each element you need to be on a different layer. Then setup your Export settings like mentioned above. You'll probably have to make a seperate door family for exterior and a seperate family for interior to get this to work correctly.
Let me know if you have any other questions about it.
Thanks for your help. I'll give it a look.
Exterior windows and doors |
Fri, Sep 6, 2013 at 7:39:11 AM
DWG Export Interior/Exterior on others than walls? |
Wed, Nov 17, 2010 at 1:57:27 AM
Looking for Large 3, 4 & 5 Panel Exterior Glass Sliding Doors. (Florida Style) |
Fri, Feb 16, 2007 at 12:39:12 PM
Glass & Window Trouble while Rendering interior view? |
Tue, Jun 19, 2007 at 4:15:22 PM
Interior/Exterior Lighting |
Fri, Oct 8, 2010 at 12:53:06 PM
Members: | 2114989 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
