58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> UCS?
Tue, Oct 3, 2006 at 8:24:21 AM | UCS?
ozgeozdamar
Does Revit have something like UCS in AutoCad? I would like to work on different angles in the same drawing? Best wishes, özge
too much to learn about it...
Tue, Oct 3, 2006 at 8:56:31 AM | RE: UCS?
rkitect
rkitect Avatar
4 Stars: 29 Votes
Yes.... Place an elevation/section at the angle you would like to work at, open that elevation/section. Et Voila! Instant, automagically updating view at the angle you want to work at! That's about as close as you're going to get. Hope it helps.
Tue, Oct 3, 2006 at 4:12:12 PM | RE: UCS?
ArchWestCY
4.5 Stars: 7 Votes
Have you tried placing a referance plane? You can draw a referance plane at any elevation , and any angle, and then draw on that plane directly. This works great for setting up extrusions that are at goofy angles. Referance planes are available on the Design Bar under the Basic, and Drafting tabs. It is also available when in a massing or extrusion mode. ArchWestCY
Sat, Oct 7, 2006 at 3:54:17 AM | RE: UCS?
ozgeozdamar
Dear rkitect and ArchWestCY, Thanks a lot, it helped a lot... Best wishes
Revit 101 questions...(pertaining to UCS)
Sat, Oct 22, 2005 at 5:20:47 PM
Shocking Survey Data, nothing drawn to a UCS! slightly off axis errors imenent!!
Mon, Dec 10, 2012 at 10:30:09 AM
How do I move Model to align with linked Architect's model?
Mon, Sep 19, 2011 at 11:00:58 AM
RAC 2009 export view to ACAD 2009
Tue, Dec 1, 2009 at 12:57:35 AM
Importing a cad file
Mon, Nov 3, 2008 at 4:47:32 AM
Page generation time: 7.1444
