60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Moving a Building
Mon, Oct 2, 2006 at 5:09:10 PM | Moving a Building
MongooseST7
MongooseST7 Avatar
After constructing our model of our proposed project we find that the building needs to be moved back. I have the site topo installed and graded out with various surfaces such as parking landscaping, curbing etc declared as separate surfaces How do I move the building. I am getting constraint errors when i move the building and the building is all screwed up. SO I undo. How do I globally or universally remove all constraints? Is this a good or bad thing to do.
Mon, Oct 2, 2006 at 7:49:09 PM | RE: Moving a Building
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Typically the site information should be in a linked file. This greatly simplifies moving the building around on the site as there are no constraints to linked files. You can copy all of the site stuff into a new file and delete it from your building file, then link them.
Hiroshi Jacobs
Tue, Oct 3, 2006 at 8:02:45 AM | RE: Moving a Building
MongooseST7
MongooseST7 Avatar
If the site information is in a linked file then how does one make void areas in the linked topo for basement modeling using the PAD command.
Wed, Oct 4, 2006 at 8:26:20 PM | RE: Moving a Building
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
You should still be able to use the pad tool in the site file.
Hiroshi Jacobs
Thu, Oct 5, 2006 at 5:58:14 AM | RE: Moving a Building
Yohan
If I understand MongooseST7 the issue is when editing the site data it is in a seperate file with no reference to the location and or condition the structure poses. Perhaps copy & paste an outline of the proposed structure to assist you in the editing the site. No doubt you will constantly have to refer between the two files.
Tue, Apr 29, 2008 at 7:18:35 AM | Moving a Building
notagain
notagain Avatar
4 Stars: 1 Votes
well it's address another way...let say you have been working for months and your client decides they want the building moved.....what's the best way to do this?
I really want this to work...some good things some bad
Tue, Apr 29, 2008 at 9:02:39 PM | Moving a Building
twometer
3 Stars: 2 Votes
You can link your building model into the site and the site into the building model.  Just make sure the link is on overlay and not attached.  If it is set to attached, it will create a circular reference.
 FYI, to have them open at the same time, you will need two sessions of Revit running on your computer.
Tue, Apr 29, 2008 at 11:17:19 PM | Moving a Building
lunchtrayrider
3.5 Stars: 7 Votes
Tools>project location/orientation>relocate this project
Very dangerous.  But pretty cool.  Practice on a file before you go for broke.
I like scooters. and motorcycles.
Wed, Apr 30, 2008 at 5:50:00 AM | Moving a Building
notagain
notagain Avatar
4 Stars: 1 Votes
Hey that’s great advice, but I am looking for something along these lines...let say you have a column grid and everyone working on that grid for month..now it's been decided to move the grid 1' north, 8" south and then drop the elevation by 2".....see all models are referenced into Intergraph package and several disciplines work on that model....
Site Plan & Moving Building Model
Fri, Mar 9, 2007 at 10:22:56 AM
Moving Building up with out moving the site
Sun, Jul 31, 2016 at 5:20:11 PM
Rotating property line and site without moving building...
Sat, Jun 15, 2013 at 10:31:21 AM
Changing level height values while keeping building in place? [ 1 2 ]
Mon, Apr 13, 2015 at 1:47:49 AM
18
moving half a building
Wed, Mar 29, 2006 at 5:23:21 PM
Page generation time: 1.1215
